eccovi u po' di comandi utili da dare da adb...
NB: Per utenti linux e mac,i comandi sono identici in tutto e per tutto a quelli sotto,dovete semplicemente aggiungere il prefisso
davanti al comando adb...
per esempio:
./adb shell
UTILIZZO:
-d - directs command to the only connected USB device
returns an error if more than one USB device is present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is running.
-s <serial number> - directs command to the USB device or emulator with
the given serial number
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices - list all connected devices
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> <local> - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] <file> - push this package file to the device and install it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories)
adb bugreport - return all information from the device
that should be included in a bug report.
adb version - show version num
DATAOPTS:
(no option) - don't touch the data partition
-w - wipe the data partition
-d - flash the data partition
scripting:
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-product - prints: <product-id>
adb get-serialno - prints: <serial-number>
adb status-window - continuously print device status for a specified device
adb remount - remounts the /system partition on the device read-write
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PDP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be updated.
- If it is "system" or "data", only the corresponding partition
is updated.
Alcuni non li ho mai usati, nč mai sentiti menzionare, perciō non mi assumo responsabilitā se il vostro terminale vi salta addosso e vi azzanna![]()
edit:su linux e mac basta impostare la variabile di sistema PATH (come faccio io di solito con eseguibili) e non c'č bisogno di mettere ./ davanti.
es. OSX (ma anche alcune distro linux)
~/.bash_profile -> alla fine del file -> PATH=/directory/android/sdk/tools:$PATH THANKS TO ELEGOS
edit 2: ecco un altro link utile -> Android Debug Bridge | Android Developers THANKS TO POLHALLEN
Gianluca
