Utente del mese: megthebest con ben 21 Thanks ricevuti nell'ultimo mese
[APK per ROOT] Framaroot
    Androidiano L'avatar di flesh97
    San Vito Lo Capo
    Samsung Galaxy S III
    Ringraziato 65 volte in 39 Posts
    Salve ho trovato andare su xda un app che permette di installare o rimuovere i permessi di root.
    Il link del thread originale su XDA è questo:
    [ROOT] Framaroot, a one-click application to root some devices - xda-developers
    ISTALLAZIONE E UTILIZZO:
    1- Installare e aprire l'app
    2- Decidere se fare un root o unroot
    3- Premere su un exploit
    4- Riavviare il cell in caso di root o unroot.
    CHANGELOG:
    Version 1.9.1: New action (Execute script) added which will allow you to execute a custom script. Ukrainian language added thanks to Bogdan.
    Version 1.9.0: Add Barahir exploit (potentially affect Mediatek based devices).
    Version 1.8.1: Another attempt to fix crashes.
    Version 1.8.0: Add Faramir exploit, little brother of Boromir (potentially affect Mediatek based devices).
    Version 1.7.1: Link to Framaroot donation added (it does nothing as this kind of application are forbidden on play store ... but it could do something someday)
    Version 1.7.0: Due to a mistake, Pippin exploit didn't appear in exploit list, its fixed now (Huawei device owners welcome). Add Gollum exploit for AMLogic based devices.
    Version 1.6.1: Remove Superuser as it fail to install. Add execution support from adb command line.
    Version 1.6.0: Add Pippin exploit (potentially affect Huawei K3V2 based devices)
    Version 1.5.3: An attempt to fix Gandalf error#10
    Version 1.5.2: Revert to exploitation fix included in 1.4.1. Add Slovakian and Italian languages. Error # added in toast message when exploit failed (report the error number in this thread so I could give you the reason of failure). Previously fix for Framaroot crash was a dirty hack, with this version you shouldn't encounter crash.
    Version 1.5.1: Should fix Framaroot crashes.
    Version 1.5.0: Add Boromir exploit (potentially affect many MT65XX based devices).
    Version 1.4.3: Update SuperSU to 1.34. Rewrote the fix include in 1.4.1 for better but slower exploitation.
    Version 1.4.2: Add Russian and French languages. Add scrollbar for exploit list. Update SuperSU to 1.30
    Version 1.4.1: Fix a bug in exploitation due to the different kernel data alignement between version and devices, so if exploits didn't work before it "may" work with this version if your device is vulnerable
    Version 1.4: Add Gandalf exploit (potentially affect Qualcomm based devices, tested on Nexus 4, as always feedbacks are welcome)
    Version 1.3: Add Aragorn and Legolas exploits (could affect wide range of samsung devices including non exynos devices, please give feedbacks for your devices. Thanks)
    Version 1.2.1: Fix unroot bug. Improvements for exploitation. Embed SuperSU 1.25
    Version 1.2: Add possibility to Install Superuser, Install SuperSU and Unroot
    Version 1.1: Frodo exploit added Version 1.0: Initial release
    DOWNLOAD:
    Scaricate dal link allegato nel thread su xda.
    Questa è la versione 1.9.1:
    Versione 1.9.1
    Se vuoi controllare se l'applicazione "Framaroot" ha eseguito i permessi di root?
    Allora scarica:
    [B]Root Checker
    Compatibility for Qualcomm devices (Gandalf exploit only) :
    Compatibility for MTK devices (Boromir, Faramir and Barahir exploits only) :
    Compatibility for Huawei K3V2 devices (Pippin exploit only) :
    Compatibility for Samsung devices (Legolas and Aragorn exploits only) :
    Compatibility for Exynos devices (Sam, Frodo, Legolas and Aragorn exploits only) :
    Compatibility for Omap36XX devices (Gimli exploit only) :
    [/SPOILER]
    Possible case once exploit is launched
    FAQ
    Io, Androidiani e lo sviluppatore dell'app non ci prendiamo la responsabilità in caso di danni allo smartphone.
    Ultima modifica di flesh97; 23-03-14 alle 11:58
    Samsung Galaxy SIII
    [ROM] Imperium Kk V1.0
    [2ndROM] Imperium v26
    [Kernel] Boeffla Kernel
    RICORDA IL QUI SOTTO A SX!
    CASALGRANDE (RE)
    SAMSUNG GALAXY S III
    A me funziona nell's3,ma x l'altro mio tab 3 10.1 (5220) no! Sai se x caso esiste x il tab 3?Grazie
    Inviato dal mio GT-P5220 usando Androidiani App
    San Vito Lo Capo
    Aggiornato il 3D all'ultima versione di framaroot e nuove compatibilità.
    Samsung Galaxy SIII
    CASALGRANDE (RE)
    Ma è ancora all'1.9.1 l'ultima vetsione!
    San Vito Lo Capo
    Quote Originariamente inviato da Beppe1984 Visualizza il messaggio
    Il mio post non era aggiornato
    Samsung Galaxy SIII
    Mar 2014
    Ho acquistato un nuovo 8core, l'Ubtel U8 MTK6592, non compare ancora nella lista dei dispositivi compatibili con framaroot, vedo però che alcuni MTK6592 sono già compatibili, posso provare in ogni caso o rischio il brick del telefono? Dalle varie recensioni viste mi pare di capire che il programma si limiti a visualizzare un messaggio di errore nel caso non fosse possibile completare il root, senza quindi compromettere il terminale nel caso questo non sia pienamente supportato, ma è veramente così o comunque restano dei rischi? Fatemi sapere per favore, mi sembra l'applicazione più affidabile ma non voglio correre rischi inutili.
    Mar 2014
    Nessuno sa darmi informazioni a riguardo? :/
  9. #8
    Androidiano L'avatar di jonicus
    P8 Lite (2017) PRA-LX1C02B153
    Ringraziato 51 volte in 32 Posts
    Quote Originariamente inviato da Castle83 Visualizza il messaggio
    Vai tranquillo, in caso non riesca ad applicare l'exploit e quindi rootare il dispositivo non compromette nulla. Come una semplice applicazione.
  10. Il seguente Utente ha ringraziato jonicus per il post:
    Castle83 (04-04-14)
  11. #9
    Mar 2014
    Quote Originariamente inviato da jonicus Visualizza il messaggio
    Ok grazie 1000, cominciavo a demoralizzarmi, senza root addio fix gps & audio eheh, non resta che incrociare le dita e vedere se funziona, grazie ancora.
  12. #10
    Androidiani Power User L'avatar di paolosv
    Jun 2009
    Ringraziato 172 volte in 108 Posts
    Appena usato con il mio Omate TS funziona alla perfezione! L importante e impostare i font piccoli!
    Motorola RazR
    Motorola Xoom
    Rom Team Eos ICS v1.0.0 3G (mz601)
    Kernel Tiamat ICS 3.0.5
    Cpu overclock Min : 216 - Max : 1504
    Governor Lagfree
    POTETE RINGRAZIARE CON IL TASTO IN BASSO A SINSTRA
