Pagina 7 di 8 primaprima ... 5678 ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 76
[Huawei Ascend G6]Thread Problemi Spazio di Archiviazione Insufficiente
  1. #61
    Dec 2015
    ciao anch'io ho lo stesso problema di folle99 non c'è nessuno che ci può aiutare. Grazie
    macerata
    perdonate l'insistenza ma ho provato a riportare il telefono g6 alla configurazione di fabbrica e in breve tempo mi sono ritrovato con gli stessi problemi... Ho provato a installare ROOT CHECKER BASIC che mi dice ROOT access is not installed on this device.
    Ho provato a passare alla versione pro di Root checker e il risultato è stato questo
    codice:
    Overall Status: Root access is not installed on this device
    Feedback Mode: Install Root
    Issue: Not installed superuser app and su binary, and unable to access root user account
    Feedback: Locate a guide for root installation on a HUAWEI G6-U10 device
    Stage 1 - Superuser App: Not Installed
    NOT installed: SuperSU by Chainfire, Superuser by ChainsDD, or Superuser by Koush
    Stage 2 - Superuser Binary Files: Not Installed
    Standard Location
    Command: ls -l /system/bin/su
    Result:  /system/bin/su: No such file or directory
    Analysis: File /system/bin/su does not exist.
    Standard Location
    Command: ls -l /system/xbin/su
    Result:  /system/xbin/su: No such file or directory
    Analysis: File /system/xbin/su does not exist.
    Alternative Location
    Command: ls -l /sbin/su
    Result:  /sbin/su: Permission denied
    Analysis: File system permissions restricted and denied access.
    Command: ls -l /system/sbin/su
    Result:  /system/sbin/su: No such file or directory
    Analysis: File /system/sbin/su does not exist.
    Command: ls -l /system/xbin/sudo
    Result:  /system/xbin/sudo: No such file or directory
    Analysis: File /system/xbin/sudo does not exist.
    Alternative System Environment Location
    Command: ls -l /vendor/bin/su
    Result:  /vendor/bin/su: No such file or directory
    Analysis: File /vendor/bin/su does not exist.
    Stage 3 - Root User Account: Error
    Error: java.io.IOException: Error running exec(). Command: [su] Working Directory: null Environment: null
    Optional - ADB Shell User
    Status: Non-Root Shell User
    Setting stored in /default.prop and configured as: ro.secure=1
    Additional - System Environment PATH
    System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin
    Results provided for your HUAWEI G6-U10 - Android 4.4.2 device by Root Checker Pro version 5.6.8 from joeykrim in Google Play - http://goo.gl/NcnHn
    Sent from Huawei Mobile
    Aiuto ora come procedo per eseguire il Root? Grazie per ogni aiuto anche su dove trovare le istruzioni passo passo Grazie
  4. #63
    Androidiano L'avatar di danout
    Poco X3 NFC
    Quote Originariamente inviato da folle99 Visualizza il messaggio
    codice:
    Standard Location
    Standard Location
    hai provato ad usare RootGenius o Kingroot?
  5. #64
    macerata
    Su un altro cell ho provato con kingroot , uno vale l'altro? Non vorrei rovinare il cellulare come si opera? Grazie
  6. #65
    Poco X3 NFC
    Al massimo non va a buon fine il root (poi va beh ovviamente un minimo di rischio intrinseco c'è sempre quindi a prescindere è sempre bene effettuare un backup prima), leggevo in giro che con Android KitKat Kingroot dovrebbe funzionare solo dopo aver sbloccato il bootloader mentre Rootgenius funziona anche senza lo sblocco. Prima di aggiornare a kk avevo usato Towelroot, poi con kk ho sbloccato il bootloader e fatto il root con adb (seguendo una delle guide online)
  7. #66
    macerata
    Grazie danout, ho scaricato dal sito web indicato direttamente sul cellulare KINGROOT e sorpresa mi sono trovato tutto in inglese, ma molto rinnovato e mi pare faccia piu di quello che mi serviva ho cliccato su try it e mi pare che mi ha installato il root infatti se chiedo a root checker mi dice che ho il root.
    Ho spostato un pò di app nella scheda sd che prima non mi si spostavano (qualcuna anche con il root continua a non spostarsi) ho dato poi un aggiornamento alle varie app che da secoli non si aggiornavano e nonostante siano spostate su sd e nonostante abbia inserito come di default la scelta dell scheda sd come memoria su cui andare a salvare ... gli aggiornamenti non mi vengono fatti e il motivo è sempre spazio insufficviente... sposto le app con app Link2SD che quando apro scrive in evidenza "Seconda partizione non trovata" è un problema se si come lo risolvo? A cosa è dovuta ancora la mancanza di spazio mannaggia?
    se esiste un programma per avere i diritti di root esiste una app che permette di rimettere il cellulare in non root e rispostarlo in root all'occorrenza?
  8. #67
    macerata
    Quello che mi sembra strano è che nella archivio telefono di 4Gb memoria interna Totali 1.86 Gb, disponibili: 0,88GB,72,73MB solo per applicazioni
    Qualcosa non torna con queste somme ...????Puo essere che dopo il root non mi funziona piu la posta elettronica invio e ricezione?
    Ultima modifica di folle99; 29-01-16 alle 00:10
  9. #68
    Oct 2014
    È normale, molta memoria è disponibile solo per cache e vari dati delle app. Spostare le app su scheda sd cambia poco o niente devi creare una seconda partizione nella memory card, prova a cercare video tutorial su you tube.
    Inviato dal mio HUAWEI G6-U10 usando Androidiani App
  10. #69
    Poco X3 NFC
    Per la memoria Meleg ti ha già risposto, per la posta era successo anche a me, ma è passato tanto tempo e non ricordo come avevo risolto (non ricordo nemmeno se era accaduto dopo il root francamente, anche perchè l'ho fatto varie volte e con diversi metodi) :S :S è una opzione da cambiare ma non ho in mente quale, prova semmai a verificare le impostazioni varie (della provider o delle autorizzazioni del programma che usi per le mail)
  11. #70
    macerata
    ho eseguito quanto descritto in questo sito per cercare di risolvere il problema di spazio. Ho fatto sulla scheda sd una partizione primaria di 15 Gb l'ho rimessa sul cell. accendendola android ha visto la partizione primaria, ma porca miseria, lo spazio di memeoria risulta ancora lo stesso di prima ed è insufficiente, ho i permessi di Root ma che cavolo ha questo cellulare?lo spazio interno del cellulare risulta ancora = a quello di prima nonostante avrebbe dovuto aver aggiunto quello della partizione primaria di 15 g appena fatta... AIUTOOOO ora lo butto!!! Eppure per il resto è fantastico!!!
