Pagina 13 di 14 primaprima ... 311121314 ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 137
Locale
  1. #121
    Senior Droid L'avatar di Tsuneku
    Sep 2010
    Ringraziato 28 volte in 28 Posts
    Ho mandato un paio di mail allo sviluppatore di Locale che molto gentilmente ha sempre risposto, mi dice che quanto segnalavo (si accendono insieme il task che soddisfa le condizioni + imp.predefinite) è normale quindi don't worry.
    Già che ci siamo: sapete che si può fare il backup?
    Backup and restore is now available as a beta feature in Locale 1.0.5. This feature is disabled by default, and must be enabled by following the instructions below.
    After backups are enabled, a new Backup menu item will appear under the menu of the Locale home screen. From that menu item, you can create a backup to the phone's SD card. When Locale is re-installed, it will automatically detect any existing backups and ask whether you'd like to restore them.
    A few notes:
    - The enabler must be installed to enable restore functionality. If you wipe your phone, don't forget to reinstall the enabler.
    - The SD card must be present and available to Android. Backup and restore will be unavailable if the SD card is mounted on your computer via USB.
    - After performing a backup, you'll have to manually disable and then enable Locale from the menu to get Locale running again
    Please let us know if you experience any issues with the backup/restore system, but please note that we can't provide any support for this feature because it is a beta
    A few notes:
    HOW TO ENABLE BACKUPS
    1. Allow installing apps outside of the Android Market
    a. Go to the Android Settings
    b. Tap on Applications
    c. Tap on Unknown sources
    2. Install Backup Enabler
    a. Open the web browser on your phone
    b. Go to this address: www.twofortyfouram.com/backup.apk
    c. Once the download completes, tap on the download
    d. Follow the instructions to install
    Ultima modifica di Tsuneku; 16-09-10 alle 22:34
    Banned
    Sep 2009
    a parte questo interessantissimo messaggio sul backup, io ho un problema...
    io uso la localizzazione gsm con il plugin location, cosi cambio volume suoneria ecc
    ho uno solo problema, appena torno a casa, se non sblocco il telefono locale non cambia situazione nonostante la cella sia cambiata... anche a voi si comporta cosi ?
  4. #123
    Sep 2010
    Quote Originariamente inviato da drastaiv Visualizza il messaggio
    Ciao, la condizione relativa alla posizione è lenta sia per preservare la batteria che per le metodologie scelte dallo sviluppatore, tra l'altro la situazione peggiora in funzione dell'ampiezza della locazione scelta per impostare il task: più ampio è il raggio e più ci mette a cambiare task.
    Personalmente ho risolto installando questo plugin gratuito:
    Locale Location Plug-In - Android app on AppBrain
    si basa esclusivamente sulle celle telefoniche. Ti consiglio di aprirla, lanciare il traking e spostarti all'interno della zona in cui vuoi che si verichi la condizione...così facendo il plugin registrerà tutte le celle della zona e switcherà in maniera pressochè istantanea ma soprattutto precisa.
    Prova e fammi sapere, per me è perfetta anche a livello di consumo della batteria (non ho notato alcun decadimento).
    Tsu.
  5. #124
    Sep 2010
    Dimenticavo un'altra HINT interessante.
    Avete notato che una volta aggiunta una condizione non se ne possono aggiungere di uguali?
    Questo perche per il software ogni condizione rappresenza una AND.
    Esempio:
    se sono le 7 del mattino E sono a casa....
    spulciando l'help ho trovato il modo di fare gli OR, ovvero:
    se sono le 7 del mattino O sono le 23 ....
    per aggiungere gli OR vi basta fare un touch su AGGIUNGI CONDIZIONE senza alzare il dito e fin quando non appare la lista che, contrariamente al singolo tap, presenterà anche le condizioni già inserite.
    Io ad esempio ho fatto:
    se sono a casa
    E sono le 7 del mattino dal lunedì al venerdì
    O sono le 9 del mattino dal sabato alla domenica
    ---> accenditi.
    Tsu
  6. #125
    Banned
    Sep 2009
    io già usavo location plugin, proprio lo stesso dell link... ed ho 3 celle nella zona che ho scelto, o almeno 3 voci... solo che aggiorna la situazione o dopo un po' di tempo o solo quando sblocco lo schermo e questo non è un granchè..
  7. #126
    Jun 2010
    Questo é uno dei motivi x cui uso Tasker
    Sent from my Milestone using Tapatalk
  8. #127
    Banned
    Sep 2009
    sicuro sicuro che tasker non ha questo problema? e poi sicuro che mi localizza anche con gsm ? già la batteria mi dura 2 giorni scarsi, se mi metto a farmi localizzare dal gps è finita
    non che mi costi tanto provarlo ma...
    Ultima modifica di drastaiv; 18-09-10 alle 20:04
  9. #128
    Jun 2010
    Io uso la cella solo x una macro che dura poco. Quando esco da una cella deve mandarmi un messaggio. Cmq trovi la trial sul sito. Provala. È gratis per una settimana. Cmq i tempi di check sono tutti personalizzabili, quindi se non dovesse farlo istantaneamente vai a vedere tra le opzioni e vedi quanto ti pesa sulla batteria, se riduci il tempo di check.
  10. #129
    Banned
    Sep 2009
    sinceramente l'ho guardato 2 secondi tasker, ha un'interfaccia scabrosa, in più non sono riuscito a trovare la localizzazione gsm... c'è un modulo aggiuntivo da installare come per locale?
  11. #130
    Sep 2009
    Ringraziato 146 volte in 132 Posts
    No, nessun modulo aggiuntivo. L'ho scritto VARI post più in su.
    Devi usare la versione PIU' RECENTE di Tasker (perché la localizzazione GSM è stata aggiunta per ultima), e quando premi "New" per aggiungere un nuovo contesto NON e ripeto NON devi scegliere "Location" ma "State", e dentro a "State" scegli "Cell Near" (celle vicine).
    Quando si apre la finestra di "Cell Near", tocca il pulsante "scan" e lui farà la scansione delle celle GSM a portata.
    Ripeto che l'ho scritto SVARIATI post fa.
Discussioni simili
  1. locale adesso anche su tattoo
    Da chtamina nel forum HTC Hero
    Risposte: 1
  2. menu Locale&Text/Touch input settings/Keyboard language
    Da ermoro nel forum HTC Dream / Tmobile G1
    Risposte: 2
  3. Programma per ricerca in locale
    Da sandris nel forum Le Applicazioni per Android
    Risposte: 0
