Utente della settimana: megthebest con ben 4 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 21 Thanks ricevuti nell'ultimo mese
Goophone i5C MTK6572 - Fix/Change MAC Address guida in inglese
    Exclamation
    sul mio blog, purtroppo non posso inserirlo... altre guide:root method - imei fix - firmware - change logo android in apple - programma di gestione - fix play store - cambiare la SD - cambiare/sostituire la batteria etc... compreso viseo guida e dowload programmi e ROM....
    Android 4.1.2
    MTK6572 1.0GHz Dual Core
    ROM: 2GB
    RAM: 512MB
    4.0 inch Capacitive Screen Smart Phone
    Built in 2GB & Li-ion Battery
    Single SIM Card
    Dual Cameras 2mb
    Quad Band
    A few China phone device MTK6577, MTK6589, MTK6572, MTK65xx has the same MAC address and it’s creating a conflict on the wifi network. This tutorial should fix the issues for you. Note, this is for rooted phones only.
    How to do it:
    Install ES Explorer from Play (or use a similar root navigator)
    ES Explorer from Play Store
    In ES Explorer, make sure ‘Root Explorer’ is ‘ON’ – (Menu button > Tools > Root Explorer)
    Make sure to allow root privileges at any time ES Explorer requests it
    Navigate to \data\nvram\APCFG\APRDEBed
    Copy WIFI to your SD
    Get it onto your computer using your method of choice (email / USB transfer / bluetooth / SugarSync etc…)
    Goophone i5C MTK6572 Install HxD Hex Editor
    HxD Hex Editor
    Open the previously copied WIFI file in HxD. It should look similar to the image above
    The MAC address starts row 1, column 4 and ends at row 1, column 9. If your problem is NVRAM Err = 0×10, check your phone’s MAC address (From home screen > Menu button > Settings > About > WLAN MAC Address) and input that value. Otherwise edit as needed.
    Important: Save as a DIFFERENT FILE NAME or otherwise backup the original WIFI file and copy back to SD
    Navigate back to \data\nvram\APCFG\APRDEBed and note the file permissions (in ES Explorer, tap and hold WIFI > More > Properties)
    Overwrite the previously existing WIFI file with your modified WIFI (renaming it back to WIFI if necessary)
    Check file permissions and change to same as the original WIFI file if required (ES Explorer, tap and hold WIFI > More > Properties > Permissions > Change)
    Bam, reboot! Please let us know how this works out for you
    If you need the change the boot logo from "android" to "apple",
    simply dial *#*#6688#*#* on the dialer and this will give you the apple logo!
    Ultima modifica di fabio0322; 16-01-14 alle 00:47
