Utente della settimana: carotix con ben 6 Thanks ricevuti negli ultimi sette giorni
Pagina 8 di 79 primaprima ... 6789101858 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 786
Tablet Altroconsumo 8" (2016/2017) - RK312x 1.3 Ghz - 1GB RAM - 8GB Flash (Modding)
  1. #71
    Apr 2011
    Bologna
    Huawei Ascend Y300
    Ringraziato 95 volte in 36 Posts
    Il build.prop:
    codice:
    # begin build properties
    # autogenerated by buildinfo.sh
    ro.build.id=LMY49F
    ro.build.display.id=rk312x-eng 5.1.1 LMY49F eng.zed.20161015.180024test80026A-keys
    ro.build.version.incremental=eng.zed.20161026.114732
    ro.build.version.sdk=22
    ro.build.version.codename=REL
    ro.build.version.all_codenames=REL
    ro.build.version.release=5.1.1
    ro.build.version.security_patch=2016-04-01
    ro.build.version.base_os=
    ro.build.date=Wed Oct 26 11:53:20 CST 2016
    ro.build.date.utc=1477454000
    ro.build.type=eng
    ro.build.user=zed
    ro.build.host=zed-B85M-D3H
    ro.build.tags=test-keys
    ro.build.flavor=rk312x-eng
    ro.product.model=791
    ro.product.brand=791
    ro.product.name=791
    ro.product.device=rk312x
    ro.product.board=rk30sdk
    # ro.product.cpu.abi and ro.product.cpu.abi2 are obsolete,
    # use ro.product.cpu.abilist instead.
    ro.product.cpu.abi=armeabi-v7a
    ro.product.cpu.abi2=armeabi
    ro.product.cpu.abilist=armeabi-v7a,armeabi
    ro.product.cpu.abilist32=armeabi-v7a,armeabi
    ro.product.cpu.abilist64=
    ro.product.manufacturer=rockchip
    ro.product.locale.language=en
    ro.product.locale.region=US
    ro.wifi.channels=
    ro.board.platform=rk312x
    # ro.build.product is obsolete; use ro.product.device
    ro.build.product=rk312x
    # Do not try to parse description, fingerprint, or thumbprint
    ro.build.description=rk312x-eng 5.1.1 LMY49F eng.zed.20161026.114732 test-keys
    ro.build.fingerprint=791/791/791:5.1.1/LMY49F/zed10171029:eng/test-keys
    ro.build.characteristics=tablet
    # end build properties
    # from device/rockchip/rk312x/system.prop
    # system.prop
    #rild.libpath=/system/lib/libreference-ril.so
    #rild.libargs=-d /dev/ttyUSB2
    # Default ecclist
    ro.ril.ecclist=112,911
    ro.opengles.version = 131072
    wifi.interface=wlan0
    rild.libpath=/system/lib/libril-rk29-dataonly.so
    rild.libargs=-d /dev/ttyACM0
    persist.tegra.nvmmlite = 1
    ro.audio.monitorOrientation=true
    persist.ril-daemon.disable = 1
    #NFC
    debug.nfc.fw_download=false
    debug.nfc.se=false
    #add Rockchip properties here
    ro.rk.screenoff_time=60000
    ro.rk.screenshot_enable=true
    ro.rk.def_brightness=200
    ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
    ro.rk.install_non_market_apps=false
    ro.rk.display_array=100,128,160
    sys.hwc.compose_policy=6
    sys.wallpaper.rgb565=0
    sf.power.control=2073600
    sys.rkadb.root=0
    ro.sf.fakerotation=false
    ro.sf.hwrotation=90
    ro.rk.MassStorage=false
    ro.rk.systembar.voiceicon=true
    ro.rk.systembar.tabletUI=false
    ro.rk.LowBatteryBrightness=true
    ro.tether.denied=false
    sys.resolution.changed=false
    ro.default.size=100
    persist.sys.timezone=
    persist.sys.boot.check=false
    ro.product.usbfactory=rockchip_usb
    wifi.supplicant_scan_interval=15
    ro.factory.tool=0
    ro.kernel.android.checkjni=0
    #set default lcd density to Rockchip tablet
    ro.sf.lcd_density=240
    ro.adb.secure =0
    # ADDITIONAL_BUILD_PROPERTIES
    ro.config.low_ram=false
    dalvik.vm.jit.codecachesize=0
    ro.com.android.dateformat=MM-dd-yyyy
    ro.config.ringtone=Ring_Synth_04.ogg
    ro.config.notification_sound=pixiedust.ogg
    ro.carrier=unknown
    ro.config.alarm_alert=Alarm_Classic.ogg
    ro.rksdk.version=RK30_ANDROID5.1.1-SDK-v1.00.00
    dalvik.vm.heapstartsize=8m
    dalvik.vm.heapgrowthlimit=80m
    dalvik.vm.heapsize=384m
    dalvik.vm.heaptargetutilization=0.75
    dalvik.vm.heapminfree=512k
    dalvik.vm.heapmaxfree=8m
    dalvik.vm.dex2oat-flags=--no-watch-dog
    dalvik.vm.dex2oat-filter=interpret-only
    dalvik.vm.image-dex2oat-filter=speed
    camera2.portability.force_api=1
    persist.sys.strictmode.visual=false
    dalvik.vm.jniopts=warnonly
    ro.rk.bt_enable=true
    ro.factory.hasUMS=true
    persist.sys.usb.config=mass_storage,adb
    testing.mediascanner.skiplist=/mnt/internal_sd/Android/
    ro.factory.hasGPS=false
    ro.factory.storage_suppntfs=true
    ro.factory.without_battery=false
    ro.setupwizard.mode=OPTIONAL
    ro.com.google.gmsversion=5.0_r1
    ro.sf.lcdc_composer=0
    debug.hwui.render_dirty_regions=false
    keyguard.no_require_sim=true
    ro.com.android.dataroaming=true
    ril.function.dataonly=1
    ro.config.enable.remotecontrol=false
    ro.rk.hdmi_enable=false
    ro.product.version=1.0.0
    ro.product.ota.host=www.rockchip.com:2300
    persist.sys.dalvik.vm.lib.2=libart.so
    dalvik.vm.isa.arm.features=div
    ro.kernel.android.checkjni=1
    dalvik.vm.dexopt-flags=m=y
    net.bt.name=Android
    dalvik.vm.stack-trace-file=/data/anr/traces.txt
    Montando lo stesso modello di processore dovrebbe essere possibile fare le stesse modifiche come sul precedente modello
    Nessuno ha provato a seguire questa guida per installare la recovery TWRP?
    Ultima modifica di Carontes; 26-01-17 alle 16:51
    Androidiano L'avatar di Fast0n
    Italia
    OnePlus One, Nexus 4
    Ringraziato 36 volte in 26 Posts
    Scopo del thread
    Scopo di questo thread è quello di discutere in merito alle funzioni base del Tablet Altroconsumo regalato da Altroconsumo a partire da fine 2016.
    Per ROM, recovery, modding fare riferimento al thread modding che verrà aperto in una seconda fase
    Abbonamento prova - Non più disponibile
    Dal 1. Gennaio non esiste più l'abbonamento di prova a 2 euro.
    C'è solo l'abbonamento annuale al 50% di sconto.
    Caratteristiche prodotto
    CPU = ARM Cortex-A7 Quad-Core 1.3GHz
    Display = TFT da 8 pollici - risoluzione 1024 x 768 pixel
    RAM = 1GB DDR3
    Flash = 8GB
    Touch = capacitivo
    Fotocamera anteriore = 2.0 MegaPixel (1600x1200 pixel)
    Fotocamera posteriore = 3.0 MegaPixel (2048x1536 pixel)
    Wi-Fi = 802.11b / g / n
    Bluetooth = versione 2.1
    GPS = non presente
    Sistema operativo = Android 5.1.1
    Ma queste caratteristiche tecniche??? La risoluzione è diversa
    Massimiliano Montaleone
    • Smartphone OnePlus One (Sandstone Black - 64GB) / LG Google Nexus 4 (White - 16GB)
    • ROM AOSP 8.1 / CyanogenMod 14.1
    • Kernel Stock
    • Recovery TWRP
  4. #73
    Italia
    Quote Originariamente inviato da Carontes Visualizza il messaggio
    Il build.prop:
    codice:
    ro.build.id=LMY49F
    ro.build.type=eng
    ro.build.user=zed
    ro.product.name=791
    ro.wifi.channels=
    # system.prop
    # Default ecclist
    #NFC
    debug.nfc.se=false
    sys.rkadb.root=0
    ro.sf.hwrotation=90
    ro.default.size=100
    ro.factory.tool=0
    ro.adb.secure =0
    ro.carrier=unknown
    net.bt.name=Android
    Io! Soft-brick
    • Kernel Stock
    • Recovery TWRP
  5. #74
    @Massy97
    A quale risoluzione ti riferisci?
    Secondo me essendo la board harwdare differente non è possibile usare gli stessi file/sistemi usati per il tablet Altroconsumo 2015 in questo modello.
    Qualcuno conosce il link del thread di Pedro Farnco dove parlano del modding di questo nuovo tabelt?
  6. #75
    Italia
    @Massy97
    caricare immagini
    • Kernel Stock
    • Recovery TWRP
  7. Il seguente Utente ha ringraziato Fast0n per il post:
    bovirus (27-01-17)
  8. #76
    @Massy97
    Se non ricordo male ho preso le indicazioni della risoluzione display da un rpecedenete post.
    Correggo il primo post. Grazie.
  9. #77
    Apr 2011
    Bologna
    Huawei Ascend Y300
    Quote Originariamente inviato da Massy97 Visualizza il messaggio
    Io! Soft-brick
    Meno male che non mi funzionavano bene i driver su windows 10 altrimenti avrebbe fatto la stessa fine. Però non mi spiego come mai, hanno lo stesso processore ma forse cambia qualcosa a livello del bootloader.
    Se è per questo nelle caratteristiche rilevate da CPU-Z c'è anche scritto 9,43 pollici mentre lo schermo dovrebbe essere un 8 pollici, quindi non mi fiderei tanto di quello che dice CPU-Z rispetto anche alla risoluzione dello schermo
    Ultima modifica di Carontes; 27-01-17 alle 11:39
  10. #78
    Italia
    Non sono sicuro che il processore sia uguale, comunque ti consiglio di fare un DUMP perfetto, prima di esegue qualsiasi operazione e se lo fai fammi sapere
    Ultima modifica di Fast0n; 27-01-17 alle 11:54
    • Kernel Stock
    • Recovery TWRP
  11. #79
    Buongiorno a tutti, sto riscontrando parecchi problemi di utilizzo e ora ve li spiego:lo accendo e incredibilmente ci sono le schede che erano rimaste aperte prima di spengerlo..... Non riesco ad attivare ne il wifi ne il bluetooth, ci premo sopra e non si attivano in nessun modo entrambi, (dal menu a tendina) mentre i 3 tasti sotto modalità aereo rotazione automatica e gps funzionano perfettamente e rispondono al comando... Cosa posso fare? Come si entra in recovery? Mi aiutate perfavore perché con la combinazione volume giù + accensione non va e neanche con volume su.....
  12. #80
    Io sono molto soddisfatto del tablettino. Come tablet 'da spiaggia' (con auricolari) è perfetto.
    L'unico neo è che non riesco a fare andare Sky go.
    L'unica versione che si installa regoarmente è la 3.01 per tablet 10.5 ma non fa vedere i canali.
    È possibile rimuovere il root per provare la versione non rootata? È un'operazione indolore?
