Utente del mese: megthebest con ben 54 Thanks ricevuti nell'ultimo mese
Pagina 2 di 2 primaprima 12
Visualizzazione dei risultati da 11 a 14 su 14
[GUIDA Z5S] Unione delle partizioni SD-DATA
  1. #11
    Jul 2016
    Thank you for your help. I had the correct adb drivers, but I couldnīt do that.
    Finally I have solved the problem with other recovery.
    In the description Hackever says that we have to use the recovery twrp 2.8.
    But that recovery doesn't work for me. With that recovery the program doesn't work in my phone.
    So I have used CWM 6.0.4.7 recovery, and with this works properly.
    Now I have my partitions merged.
    Thank you.
    Feb 2014
    oneplus one, zte nubia z5s
    Ringraziato 66 volte in 53 Posts
    ATTENZIONE la versione protetta da password di tool studio contiente un Trojan! usate windows defender per rimuoverlo
    Trojan:Win32/Rundas!plock
    Alert level: Severe, This threat can perform a number of actions of a malicious hacker's choice on your PC.
  4. #13
    May 2016
    Localitā
    Russia
    Nubia Z5S 32 gb
    Quote Originariamente inviato da marcbra Visualizza il messaggio
    With the unbrick guide, you have to reset your phone as when you bought it, and all files will be deleted, so make a backup.
    The guide with using tool studio, I am right? And I get a stock rom with stock recovery? It's guide for both versions 16 and 32 gb?
  5. #14
    Oct 2010
    Localitā
    Crotone
    ZTE Nubia Z5S 32gb
    Ringraziato 30 volte in 29 Posts
    Quote Originariamente inviato da SergMakarov Visualizza il messaggio
    Yes with tool studio, you will get the stock rom and the stock recovery, the guide is for both storage sizes.
    Inviato dal mio NX503A usando Androidiani App
