Find 7 ColorOS 2.0.0i Beta
E' la prima beta di ColorOS 2.0. E' consigliato effettuare un backup della rom corrente prima di installare questa.
Refined UI Design
The ColorOS 2.0 has inherited the UI design of ColorOS 1.0 yet with careful redesign, by removing redundant info from previous icons the new icons are more minimalistic.
The global Gaussian blur effect make the whole system looks more beautiful and consistent in different interfaces.
System Wide Transition Animation
The ColorOS 2.0 is more energetic, with system wide redesigned transition animation the whole system comes alive, you'll get the feeling that the phone is knowing what you are doing and very responsive to each and every one of your operation.
Live Weather 2.0
New weather effect Haze gives you a direct reflection of the ever worsening air quality in all over the world. Sound effects and surprises awaiting in the live weather 2.0.
Task Manager Redesign
The new task manager design shows every task running in background as a card you can simply slide it up to close it or slide it down to lock it or tap the end all button to close them all (locked apps will not be closed).
Free Halt - Single Handed Operation
When the screen gets larger and larger single handed operation is no longer a consideration for many phones, however with ColorOS 2.0 all is coming back again.
By swiping into the screen from the down left/right corner you can move the whole screen with your hand move it to a comfortable position and the button that is not easily touched with one hand is now very easy to operate.
Easy Crop for Screenshots
Immediately after a screenshot you can crop it simple by draw out the area you wanted to crop it, then you can choose to share it or send with a single tap. Saving both time and data usage, share a screenshot has never been easier.
Deep Power Saving
By reducing animation, underclocking the CPU or shutdown all applications except for calls and messages your phone can be under deep power saving mode so as increase the battery life as much as possible.
Voice Wake-up
By talking to the phone "Hey, snapdragon" you can wake-up your phone and enable Google now automatically, thus ask Google about the weather etc. without having to touch your phone.
OTA
E' una versione beta, quindi non disponibile via OTA.
Download
Filename: X9006ColorOS_V2.0.0i_Beta_full.zip
File size: 941MB
MD5 Checksum: 7f6f94fa41fd6d775a5bb821bf7cc0ff
Download: [CLICK HERE]
Installazione
Seguire le istruzioni
iNota: l'update effettuerà il wipe della partizione /data mentre i dati sulla memoria interna di archiviazione non saranno eliminati.
Source and more info: original thread on OppoForums.com
