non č uno scherzo xD
Forse Potremo avere ics,jb o kitkat
Potremo modificare anche la frequenza della GPU
Questa č una buona notizia
Curiosando nei driver, sopratutto con il file readme.txt presente nel pacchetto, diciamo che i driver sono giā "ottimizzati" per un ipotetico ICS e si possono usare per un AOSP.
PS: Da anche una "mini-guida" per provare a compilare i driver in un ICS sempre in quel file
codice:This package contains the Broadcom Android ICS Graphics stack for arm v5 ================================================================== Package contents: a new folder that contains the Graphics stack source codes: ----------------------------------------------------------------- brcm_usrlib/dag Required file changes in existing AOSP repos to build this Graphics stack ----------------------------------------------------------------- AOSP repo name: repo_aosp/platform/bionic libc/private/bionic_tls.h AOSP repo name: repo_aosp/platform/build core/legacy_prebuilts.mk target/board/generic/device.mk AOSP repo name: repo_aosp/platform/external/webrtc src/common_audio/resampler/main/source/Android.mk src/common_audio/signal_processing_library/main/source/Android.mk src/common_audio/vad/main/source/Android.mk src/modules/audio_processing/aec/main/source/Android.mk src/modules/audio_processing/aecm/main/source/Android.mk src/modules/audio_processing/agc/main/source/Android.mk src/modules/audio_processing/main/source/Android.mk src/modules/audio_processing/main/test/process_test/Android.mk src/modules/audio_processing/main/test/process_test/process_test.cc src/modules/audio_processing/main/test/unit_test/Android.mk src/modules/audio_processing/ns/main/source/Android.mk src/modules/audio_processing/utility/Android.mk src/system_wrappers/source/Android.mk AOSP repo name: repo_aosp/platform/frameworks/base opengl/include/EGL/eglext.h opengl/libagl/egl.cpp opengl/libs/EGL/egl.cpp opengl/libs/EGL/eglApi.cpp opengl/libs/EGL/egl_entries.in opengl/libs/EGL/getProcAddress.cpp opengl/libs/GLES2/gl2.cpp opengl/libs/GLES_CM/gl.cpp services/input/InputReader.cpp services/surfaceflinger/Android.mk services/surfaceflinger/DisplayHardware/DisplayHardware.cpp AOSP repo name: repo_aosp/platform/hardware/libhardware Gralloc changes: include/hardware/fb.h modules/gralloc/Android.mk modules/gralloc/framebuffer.cpp modules/gralloc/gr.h modules/gralloc/gralloc.cpp modules/gralloc/gralloc_priv.h modules/gralloc/mapper.cpp Hwcomposer changes: modules/gralloc/Android.mk modules/hwcomposer/Android.mk modules/hwcomposer/hwcomposer.cpp AOSP repo name: repo_aosp/platform/system/core include/system/graphics.h ================================================================== Instructions to build this Graphics stack on Android ICS project: 1. Check out a Android ICS (example: android-4.0.1_r1.1) workspace with the following sequence of commands: repo init -u https://android.googlesource.com/platform/manifest -b android-4.0.1_r1.1 repo sync -j8 2. Extract the content of this package (excludes this README.txt) in the root directory of the Android ICS workspace: 3. Build the Android source tree with the following sequence of commands: source build/envsetup.sh lunch full-eng make -j8 TARGET_DEVICE=generic_armv5
Ultima modifica di Bokkio; 01-03-14 alle 18:14 - Motivo: aggiunto il contenuto del file readme.txt
Ci stanno lavorando sui driver?
Si. Č al lavoro il BroadcomCM
cascella98 (01-03-14)
Grandioso! Non vedo l'ora di poter mettere JellyBean
I miei progetti:
[ROM][PORT]Hyperion8.5 BETA - Samsung GT-S5570i
La pre-alpha arriverā la prossima settimana
Froncillo (02-03-14)
rifaccio la domanda: si potranno fare porting di altri sistemi operativi?
Se ti ho aiutato lascia un thanks!!
Smartphone: Nexus 5 32GB
ROM: Resurrection Remix/SailfishOS (Multirom)
Kernel: ElementalX
Root: SuperSU
In che senso
nel senso: si potrebbe fare un porting di ubuntu touch o jolla, firefox os, etc etc?
Kernel: ElementalX
Root: SuperSU
Alleluja! ^^
