Utente del mese: bluemask con ben 15 Thanks ricevuti nell'ultimo mese
Pagina 12 di 12 primaprima ... 2101112
Visualizzazione dei risultati da 111 a 113 su 113
[OP7 Pro][INFO][OFFICIAL][ROM] Oxygen OS | Aggiornamenti ufficiali
  1. #111
    kmd
    kmd non è in linea
    OnePlus 9Pro, OnePlus 11
    Ringraziato 5,065 volte in 3,949 Posts
    Disponibile la OxygenOS 12 stabile per OP7 Pro via OTA
    OnePlus 7 Pro: GM1913_11.H.30
    Changelog:
    System
    • Adds Smart Battery Engine, a feature that prolongs your battery life based on smart algorithms and biomimetic self-restoration technology.
    • Redesigns app icons using new materials to give more depth and a greater sense of space and texture to the icons.
    • Revamps the page layout based on the principle of reducing visual noise and optimizes the presentation of text and color to make key information stand out.
    • Optimizes desktop icons with improved textures, by using a design inspired by brand-new materials and uniting lights and layers.
    • Optimizes spam block rules and adds a rule for blocking MMS messages.
    Games
    • Adds the HyperBoost end-to-end frame rate stabilizer.
    • Adds Voice effect preview to allow you to record your voice effect or check your voice effect in real time.
    Dark mode
    • Dark mode now supports three adjustable levels, bringing a more personalized and comfortable user experience.
    Shelf
    • Adds New additional style options for Cards, making data contents more visual and easier to read.
    • Newly adds access to OnePlus Scout in Shelf, allowing you to search multiple contents on your phone, including Apps, Settings, Media Data, etc.
    Work-Life Balance
    • Work-Life Balance feature is now available to all users, allowing you to effortlessly switch between Work and Life mode via quick settings.
    • WLB 2.0 now supports automatic Work/Life mode switching, based on specific locations, Wi-Fi network, and time, also bringing customized App notification profiles according to the personalization.
    Gallery
    • Gallery now allows you to switch between different layouts with a two-finger pinch gesture, intelligently recognizing the best-quality pictures, and cropping the thumbnail based on the content, making the gallery layout more pleasing.
    Canvas AOD
    • Canvas AOD brings you new diverse styles of lines and colors, for a more personalized lock screen experience with inspiring visuals.
    • Newly adds multiple brushes and strokes and supports for color adjustment.
    • Optimizes software algorithm and improved face recognition to better identify the features and skin color of different figures.
    Accessibility
    • Optimizes categorization of functions by grouping them into vision, hearing, interactive actions, and general.
    • TalkBack supports more system apps including Photos, Phone, Mail, and Calendar.
    Inviato dal mio NE2213 utilizzando Tapatalk
    Ultima modifica di kmd; 27-10-22 alle 18:49
    kmd
    kmd non è in linea
    Disponibile l'ultima Rom
    GM1913_11_H.36
  4. #113
    kmd
    kmd non è in linea
    Disponibile l'aggiornamento alla versione
    GM1913_11_H.40
