codici segreti galaxy s2
    Senior Droid L'avatar di kenwood
    Note 4 + Gear S
    Ringraziato 31 volte in 29 Posts
    Ecco alcuni codici segreti per Galaxy S2.
    Per inserire questi codici, dovrete digitarli come se stesse componendo un numero per effettuare una chiamata, vediamo ora nel dettaglio i codici:
    *#06# = IMEI Number.
    *#1234# = Firmware Version.
    *#2222# = H/W Version.
    *#8999*8376263# = All Versions Together.
    *#8999*8378# = Test Menu.
    *#4777*8665# = GPSR Tool.
    *#8999*523# = LCD Brightness.
    *#8999*377# = Error Menu.
    *#8999*327# = EEP Menu.
    *#8999*667# = Debug Mode.
    *#92782# = PhoneModel. (Wap)
    #*5737425# = JAVA Mode.
    *#2255# = Call List.
    *#232337# = Bluetooth MAC Adress.
    *#5282837# = Java Version.
    #*4773# = Incremental Redundancy.
    #*7752# = 8 PSK uplink capability bit.
    #*7785# = Reset wakeup & RTK timer cariables/variables.
    #*7200# = Tone Generator Mute.
    #*3888# = BLUETOOTH Test mode.
    #*7828# = Task screen.
    #*#8377466# = S/W Version & H/W Version.
    #*2562# = Restarts Phone.
    #*2565# = No Blocking? General Defense.
    #*3353# = General Defense, Code Erased.
    #*3837# = Phone Hangs on White screen.
    #*3849# = Restarts Phone.
    #*3851# = Restarts Phone.
    #*3876# = Restarts Phone.
    #*7222# = Operation Typ: (Class C GSM)
    #*7224# = !!! ERROR !!!
    #*7252# = Operation Typ: (Class B GPRS)
    #*7271# = CMD: (Not Available)
    #*7274# = CMD: (Not Available)
    #*7337# = Restarts Phone. (Resets Wap Settings)
    #*2787# = CRTP ON/OFF.
    #*2886# = AutoAnswer ON/OFF.
    #*3737# = L1 AFC.
    #*5133# = L1 HO Data.
    #*7288# = GPRS Detached/Attached.
    #*7287# = GPRS Attached.
    #*7666# = White Screen.
    #*7693# = Sleep Deactivate/Activate.
    #*7284# = L1 HO Data.
    #*2256# = Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt)
    #*2286# = Databattery.
    #*2527# = GPRS switching set to (Class 4, 8, 9, 10)
    #*2679# = Copycat feature Activa/Deactivate.
    #*3940# = External looptest 9600 bps.
    #*4263# = Handsfree mode Activate/Deactivate.
    #*4700# = Please use function 2637.
    #*7352# = BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF)
    #*2558# = Time ON.
    #*3370# = Same as 4700.
    #*3941# = External looptest 115200 bps
    #*5176# = L1 Sleep.
    #*7462# = SIM Phase.
    #*7983# = Voltage/Freq.
    #*7986# = Voltage.
    #*8466# = Old Time.
    #*2255# = Call Failed.
    #*5187# = L1C2G trace Activate/Deactivate.
    #*5376# = DELETE ALL SMS!!!!.
    #*6837# = Official Software Version: (0003000016000702)
    #*7524# = KCGPRS: (FF FF FF FF FF FF FF FF 07)
    #*7562# = LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01)
    #*2337# = Permanent Registration Beep.
    #*2474# = Charging Duration.
    #*2834# = Audio Path. (Handsfree)
    #*3270# = DCS Support Activate/Deactivate.
    #*3282# = Data Activate/Deactivate.
    #*3476# = EGSM Activate/Deactivate.
    #*3676# = FORMAT FLASH VOLUME!!!
    #*4760# = GSM Activate/Deactivate.
    #*4864# = White Screen.
    #*5171# = L1P1.
    #*5172# = L1P2.
    #*5173# = L1P3.
    #*7326# = Accessory.
    #*7683# = Sleep variable.
    #*8465# = Time in L1.
    #*2252# = Current CAL.
    #*2836# = AVDDSS Management Activate/Deactivate.
    #*3877# = Dump of SPY trace.
    #*7728# = RSAV.
    #*2677# = Same as 4700.
    #*3728# = Time 2 Decod.
    #*3725# = B4 last off.
    #*7372# = Resetting the time to DPB variables.
    #*7732# = Packet flow context bit Activate/Deactivate.
    #*6833# = New uplink establishment Activate/Deactivate.
    #*3273# = EGPRS multislot. (Class 4, 8, 9, 10)
    #*7722# = RLC bitmap compression Activate/Deactivate.
    #*2351# = Blinks 1347E201 in RED.
    #*4472# = Hysteresis of serving cell: 3 dB
    #*2775# = Switch to 2 inner speaker.
    #*9270# = Force WBS.
    #*7878# = FirstStartup. (0=NO, 1=YES)
    #*3757# = DSL UART speed set to. (LOW, HIGH)
    #*8726# = Switches USBACM to Normal.
    #*8724# = Switches USBACM to Generator mode.
    #*8727# = Switches USBACM to Slink mode.
    #*8725# = Switches USBACM to Loop-back mode.
    #*3838# = Blinks 3D030300 in RED.
    #*2077# = GPRS Switch.
    #*2027# = GPRS Switch.
    #*0227# = GPRS Switch.
    #*0277# = GPRS Switch.
    #*8370# = Tfs4.0 Test 0.
    #*8371# = Tfs4.0 Test 1.
    #*8372# = Tfs4.0 Test 2.
    #*8373# = Tfs4.0 Test 3.
    #*8374# = Tfs4.0 Test 4.
    #*8375# = Tfs4.0 Test 5.
    #*8376# = Tfs4.0 Test 6.
    #*8377# = Tfs4.0 Test 7.
    #*8378# = Tfs4.0 Test 8.
    #*8379# = Tfs4.0 Test 9.
    #*22671# = AMR REC START.
    #*22672# = Stop AMR REC. (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
    #*22673# = Pause REC.
    #*22674# = Resume REC.
    #*22675# = AMR Playback.
    #*22676# = AMR Stop Play.
    #*22677# = Pause Play.
    #*22678# = Resume Play.
    #*77261# = PCM Rec Req.
    #*77262# = Stop PCM Rec.
    #*77263# = PCM Playback.
    #*77264# = PCM Stop Play.
    #*22679# = AMR Get Time.
    *#8999*364# = Watchdog ON/OFF.
    *#8999*427# = WATCHDOG signal route setup.
    *2767*226372# = Camera Reset. (deletes photos)
    *2767*3855# = E2P Full Reset.
    *2767*2878# = E2P Custom Reset.
    *2767*927# = E2P Wap Reset.
    *2767*226372# = E2P Camera Reset.
    *2767*688# = Reset Mobile TV.
    #7263867# = RAM Dump. (On or Off)
    *#0*# = testing sensors and other stuff (thanks karfeef)
    *#0011# = ServiceMode/Debug/Basic Information (thanks Croak)
    VOLUME BOOSTING
    Aumentare il volume delle cuffie:
    *#9072641*# – 2 EAR config – 3 Ringtone volume – Vedrete settato 6, aumentatelo fino a 10.
    Aumentare il volume dei video:
    *#9072641*# – 3 SPK config – 3 Ringtone volume – Vedrete settato 6, aumentatelo fino a 10.
    Mar 2009
    Il thread ci sarebbe già..ma una ripassata per i nuovi non fa male
    inviato dal mio iPhone 5 Bianco in esclusiva mondiale
    Senior Droid L'avatar di labeppanza
    Torino
    MotorolaA1000 iPhone evo3d s2
    Ringraziato 29 volte in 26 Posts
    Quote Originariamente inviato da kenwood
    #*3737# = L1 AFC.
    #*2558# = Time ON.
    #*5176# = L1 Sleep.
    #*7986# = Voltage.
    #*8466# = Old Time.
    #*5171# = L1P1.
    #*5172# = L1P2.
    #*5173# = L1P3.
    #*7728# = RSAV.
    VOLUME BOOSTING
    Scusa ma il codice *#9072641*# io non riesco ad inserirlo o meglio non accade nulla.... Puoi provarlo e dirmi se ti funziona??
    Androidiano VIP L'avatar di Warriors993
    Palermo
    Samsung Galaxy S II - LG G2
    Ringraziato 272 volte in 199 Posts
    Quote Originariamente inviato da labeppanza Visualizza il messaggio
    Se hai su la cm9, allora e per questo motivo. Io ho la cm9 e molti comandi non vanno, se non dire la maggiorparte xD
    Torino
    Quote Originariamente inviato da Warriors993
    No non ho neanche il root...
    Lo stesso succede a me: digitando *#9072641*# non succede niente; io sono ancora Wind
    Torino
    Secondo me sono vecchi questi codici e andrebbero provati...io i primi cinque li ho provati e funzionano....
  9. #8
    *#9072641*# non funziona.......volevo alzare il volume delle cuffie....
